Chewy buildz Posted 10 hours ago Posted 10 hours ago Hi, would appreciate any thoughts you may have. I’ve just swapped a known good VQ35DE into my 2003 UK manual 350Z, using the donor engine and harness but keeping the original ECU. It starts and revs fine, but has a bad misfire at idle. Only code is P0300. I’ve narrowed it down to cylinder 6 because unplugging that coil makes no difference at all. So far I’ve: Swapped the coil with cylinder 2 Swapped the spark plug Swapped the injector Confirmed the injector is clicking Confirmed injector pulse with a noid light Compression tested cylinder 6 at 185 psi Smoke tested the intake with no leaks found Confirmed 12.5V at the coil connector Checked continuity from the coil wiring back to the ECU Checked the engine grounds and added a direct ground from battery negative to the engine Unplugged the MAF, which made it run worse The fault has stayed on cylinder 6 through all of this. Bank 2 short term fuel trim was around +25%. The donor engine ran perfectly before it came out. I did remove and refit the crank sensor during the swap. I’ve got an oscilloscope arriving tomorrow, so my next step is comparing the ignition trigger on cylinder 6 with a working cylinder. Has anyone come across something similar after a VQ35DE swap? Quote
Keith D Posted 9 hours ago Posted 9 hours ago Think the fuel trim is a big clue, 25% is very high. My 370z is no more than 5%. I'd check with the scope as you plan. If that's fine I'd do a leak down test (cam lobe, spring, valve bent etc...) compression test doesn't always pick these up. Then I'd look for an air leak (plenum gasket runner 6 maybe). PCV valve is on bank 2 and connects near runner 6 -can you smoke test the PVC hole? Quote
