Clutch master cylinder now! Replacement quide needed help!
Hi
Some will recal i droppwd onto a 350z rag top which was standing for 13yrs.  Innevitably, now its being used daily issues are arrising lol.
I cjanged the slave clutch cylinder after pedal to floor issues and it wont bleed so now purchased a master cylinder.
Ive removed all the engine bay pipes and gubins easy enough but cant even see the two 12mm bolts to put a socket on!
Do i need to drop the entire pedal box and ecu to gain access?
Peed off and missing the drive thrills so please help i wanna get this done and bled tomoz. Back on road asap.
Thanks
Bongo dave x
Just drop the lower trim above the pedals.
The 2 bolts and the clevis pin can be reached from there.
The ECU will not get in the way as it is on the other side.
Top Tip:  Bench Bleed the slave and master before fitting.
There is a bcm or ecu above brake pedal below steering column with bcm caged connection whats this then pls?
Thanks for reply btw
Bongo
Edited by BongoDiv
Coxk up
