Oil pressure relief valve 2006 350z
Hello
im having a bit of a problem i had gotten my engine rebuild but the shop forget to put the new oil pressure release valve in the upper oil pan does anyone know how to get it in the upper oil pan
It’s not in the oil cooler the one Vq that have them in the oil cooler are 2009-up
the problem is that i don’t know if I’m supposed to remove the wholee upper oil pan to be able to if it in the upper oil pan where it belongs
53 minutes ago, ZMANALEX said:
The image in the schematic is from the outside.
Mmm interesting man I wish there was a video on how to change it
How would you go about putting it in and can I run the engine with out it in case I need it take it to a shop i know it dumb to ask as if probably helps hold the oil pressure
Why not take it back to the shop that built your engine as they are the ones that messed up?
In answer to your question, you can not run without the valve.
Why do you want to change the valve?
In answer to your questionyou can not run without the valve.
Why do you want to change the vachange it  I
I don’t want to change it the shop forget to put it in so I’m trying to get a understanding of how to put it in so that why I can get the motor started for the first time
So are you saying that the shop built the engine and forgot to fit the valve?
In that case, simply tap the new valve into the hole where the valve is meant to be.
INSPECTION AFTER REMOVAL Oil Cooler Check oil cooler for cracks. Check oil cooler for clogging by blowing through engine coolant inlet. If necessary, replace oil cooler. Relief Valve: Check relief valve for movement, cracks and breaks by pushing the ball. If replacement is necessary, remove relief valve by prying it out with suitable tool. Install a new relief valve in place by tapping it. INSTALLATION Note the following, and install in the reverse order of removal. ● Make sure that no foreign objects are adhering to the installation planes of oil cooler and oil pan (upper). ● Align cutout on oil cooler with protrusion on oil pan (upper) side, and tighten connector bo
I have replaced a few of these over the years, however as you appear to question some of what I write I just did a copy and paste from the Nissan workshop manual for you.
  • 1 year later...
hi,what suitable tool to remove this valve?cheers
