Anthony23 Posted August 23, 2021 Posted August 23, 2021 Quick question regarding an apparently common fault with the HR (2007, 86k miles). My oil pressure is reading quite low at hot idle - around 10-15psi - and I'm aware it could well be the oil gallery gasket needing to be replaced. My issue is with trying to get a garage to externally measure the oil pressure and/or replace the gasket. Does anyone know of a garage/specialist in the Southwest who would be able to do this? If all fails I'll have to take it to Horsham. Cheers. Quote
Anthony23 Posted August 23, 2021 Author Posted August 23, 2021 I'm in St. Ives, Cornwall, almost couldn't be further Southwest 😅 Quote
ZMANALEX Posted August 23, 2021 Posted August 23, 2021 As far as I know Horsham may be the closest. Â However, there may be a specialist closer to home that I am not aware of. Â Quote
