Hi all,
I know there have been similar questions on this in the past, but I haven't quite found exactly what I'm looking for...
Basically I'm getting an engine error code P0350 (and only that code) - first off I was getting it with no apparent issues with drivability. I changed the leads and spark plugs, everything seemed fine for a while and then the error started to return again.
Now I'm getting a misfire pretty much constantly (it's there at idle and under load). I know that P0350 code is coil circuit, so I'm guessing it's a coil pack that's gone down?
If I had the money, I'd change all the coil packs but I'm sadly not quite rich enough at the moment :(
So...
1. What's the best way to figure out which cylinder has gone down? Is there an easy method or should I pull the plugs and look for a spark on each one individually?
2. Could anything else be wrong? I read that I should check the earth cable at the front of the engine... I've checked it and can confirm it's there :D - how should I test for continuity, as it seems to disappear into a bigger loom?
3. It's a JDM '03 model. The coil packs all seem to be around £100 each. Are there any cheaper alternatives that actually work?
Sorry if this is really basic and I've missed a post covering it.
Any help greatly appreciated.
Chris.
New coil packs are in stock for your model at £39.50 each.
See my signature below.
Just drop me a message if I can help further.
Alex.
