jdm2003 Posted July 15, 2017 Posted July 15, 2017 (edited) I cant seem to get any PC programs to communicate with my cars ECU. the PC can connect to the ODBII Interface with some programs but never the ECU. sending AT commands from a console through COM seems to get a response when i monitor all (AT MA). i get a data stream from that command I have looked up what consult interface sends to the ecu in bytes. there is an initiation sequence the ecu will not respond unless this is sent. some information is available on setting up the ELM to talk to the JODB Nissan 2003 ecu. but i found it not much help when using a pc program. ECU Initialization Sequence. HEX 0xFF 0XFF 0XEF dose any one know how to send this sequence vi AT commands in a console? lol have attached some information on Nissan consult Consult_Protocol_&_Commands_Issue_6.pdf Generic_Nissan_ECU_Sensor_or_Data_register_table_Ver_2.pdf Edited July 15, 2017 by jdm2003 added documents Quote
jdm2003 Posted August 10, 2017 Author Posted August 10, 2017 Bump I found a combo that works for the nissan Z33 2003 non OBD KKL VAG-COM 409.1 USB Cable OBD2 II OBD Diagnostic Scanner VW/Audi/Seat VCDS Although it says VW/Audi/Seat VCDS, The adaptor name is correct KKL VAG-COM 409.1. http://www.ebay.co.uk/itm/272600200890 this works with Nissan Datascan2 http://home.exetel.com.au/nds/NDSII/index.php Quote
SpeedyZee Posted August 15, 2017 Posted August 15, 2017 Have you got any further with this ? Been a long long time since I messed with OBD commands and the like and my memory is a bit hazy on it now. Have a look at this page see if it helps you though https://theksmith.com/software/hack-vehicle-bus-cheap-easy-part-1/ Quote
jdm2003 Posted January 16, 2018 Author Posted January 16, 2018 Thanks i did find a solution the car is JODB i had to use nissan datacan software and a Ka Vag cable. Quote
