Problem fitting exhaust touching chassis?
Early 2006 DE... Passenger side from manifold back is sitting loads higher than the drivers side. Berk Decats arrived and fitted but still touching chassis on passenger side. It's an invidia gemini system. Had the same problem with my aftermarket y-pipe and now this. Can anybody tell me the cause of this or the fix because I'm getting pretty sh*tty with it now...
Sent from my SM-G935F using Tapatalk
Possible youve got an engine mount on the way out? Or perhaps gearbox leaning backwards causing lift to the engine? Thats where Id look first, not much else that could be upsetting the positioning?
