both rear wheel bearings needed, Calling all Traders
ph 7
Well rather bizarrely after saying that my car has been good for the 200k mileage it seems I tempted fate
On MOT test both of my rear bearings have excessive play.
Can I have some pricing on some replacements please?
UK spec 04 350z with standard power output.
They were both only replaced within the last 25k miles. Surely they should last longer than that! Zero drifting or track abuse has occurred, just uk roads.
If there is an aftermarket/uprated part available then I would also be interested in that as an option. but i'm guessing that would be for far bigger power outputs than mine
Need them pretty sharpish as my MOT runs out on the 4th
Well an update on timings. I will be having the work done Monday / Tuesday so I only need the supply of the bearings for Friday.
I suppose I should have put this in wanted, if a friendly mod wishes to shift it, thanks in advance.
Hi Jon,
Yeah, new would be my preferred, thanks for the offer though.
2nd update on timings is that I will drop the car to the garage on Monday morning which takes the pressure off delivery a little.
