Kernow Posted May 14, 2016 Posted May 14, 2016 A couple of days ago I removed the green battery disconnect screw on the negative terminal and cleaned the thread on my. After reconnecting the battery with this screw the car doesn't honk when it locks and unlocks and beeps after I turn off the ignition, then the alarm goes of when I get out of the car and close the door! Very frustrating. It isn't immobilised and drives fine. Is there an alarm reset I can do? So far I've tried holding the lock and unlock together on the fob and manually unlocking and locking the doors but nothing has changed. Cheers Quote
Kernow Posted May 14, 2016 Author Posted May 14, 2016 Update: Just tried turning on the ignition and locking and unlocking using the button on the car door but no luck Quote
Irn Bru Posted May 14, 2016 Posted May 14, 2016 Have you tried completely disconnecting the battery for 10 mins and then re connecting, sometimes this will allow a fault to clear. Quote
Kernow Posted May 14, 2016 Author Posted May 14, 2016 Nice, simple fix thanks for the dash of common sense I should have tried turning it off and on again before posting Quote
Irn Bru Posted May 14, 2016 Posted May 14, 2016 Nice, simple fix thanks for the dash of common sense I should have tried turning it off and on again before posting Glad your sorted Quote
