Spatt Posted August 14, 2015 Posted August 14, 2015 Hi folks I suspect my engine and or gearbox mounts are shot. Has anyone changed theres and what are these "Poly bushes" my friends keep telling me about Hoping there is an easy DIY guide and they're not too pricey, Any info advice would be great. Thanks Matt Quote
Cookie Posted August 14, 2015 Posted August 14, 2015 I know the gearbox mount is quite easy to do. Quote
Ridz Posted August 14, 2015 Posted August 14, 2015 (edited) Hi Matt, You may wish to PM Ewen at Clark Motorsport, they stock Powerflex engine mounts for the 350Z, I'm sure he will offer advice on both engine and gearbox mounts. Earlier posts on the forum, have indicated that changing gearbox mountings can improve shift characteristics and reduce noise/vibration. I understand that the generic term, "polybushes" refers to steering/suspension bushes. Ridz Edited August 14, 2015 by Ridz Quote
Spatt Posted August 16, 2015 Author Posted August 16, 2015 Cheers ridz I'll get in touch. I believe from a little research it's two engine mounts and one gear box mount. I'm having big problems with shifting gear near the limiter and a friend recommend either "polybushing" or solid mounts.. Need to get this done because it's destroying my y pipe I think.. I've been through two y pipes in 12 months Quote
