MattRwebB Posted July 31, 2015 Posted July 31, 2015 (edited) Simple question I hope How do you change the voltage oil pressure and speedo meter computer to a different colour LED do I need to change any backing or coloured film or is it just a straightforward LED swap? Also what LED's do I need?? Can I also change the LEDs for the buttons that control my sat nav ? (350z HR) And is there any backing or coloured film to that too or just an LED swap Same again for the speedo clocks Want them all white Edited July 31, 2015 by MattRwebB Quote
veilside z Posted July 31, 2015 Posted July 31, 2015 Led's have been changed before. Start with the gauges above cubby as a test. Quote
MattRwebB Posted July 31, 2015 Author Posted July 31, 2015 Do they have a coloured filter over them ? Sent from my iPhone using Tapatalk Quote
ZeppoJeff Posted July 31, 2015 Posted July 31, 2015 Simple question I hope How do you change the voltage oil pressure and speedo meter computer to a different colour LED do I need to change any backing or coloured film or is it just a straightforward LED swap? Also what LED's do I need?? Can I also change the LEDs for the buttons that control my sat nav ? (350z HR) And is there any backing or coloured film to that too or just an LED swap Same again for the speedo clocks Want them all white I did this to a past car i had and changed all the surface mount leds from an orange to a blue. Not really something for someone that doesnt know how to use a soldering iron as these components are pretty small and easily buggered if heat is left on them for just a little bit. Quote
MattRwebB Posted July 31, 2015 Author Posted July 31, 2015 So can't just do a led swap as I hoped lol Sent from my iPhone using Tapatalk Quote
ZeppoJeff Posted July 31, 2015 Posted July 31, 2015 no no as each individual surface mount LED would have to be soldered off and then soldered back on...gutting I know Quote
MattRwebB Posted August 8, 2015 Author Posted August 8, 2015 Is there anyone that can do this ? i found someone in amerce that can but too far away .. i can't use a soldering iron, tried once before didn't end well... I want both my Volts, Oil, and comp gauge done and speedo clocks Quote
