Tail,side and number plate lights not working
Hi all went to change a rear light bulb today, all other lights where working ok before, changed bulb and now all tail,side and number plate lights will not work, brake and headlights still work :scare:
Have checked the fuses under the bonne and in the foot well and can't see a blown fuse so a bit confused :surrender:
Any ideas please???
Are you sure you checked all the fuses? sounds like it is blown. The side lights, rear lights and number plate lights are all on the same circuit.
The fuse in question is a 10a fuse and is located in the box hidden behind the battery. As you're looking down on the box I believe it's the first 10a (red) as you work your way from the top down.
