Piranha Posted March 4, 2015 Posted March 4, 2015 Mine has snapped exposing the post, any ideas where to get a replacement? Thanks Quote
kingrob Posted March 4, 2015 Posted March 4, 2015 Hi mate i think i saw a post where you said you had a JDM car and battery i would advice to do that same as me replace the battery for a UK spec one there are traders on here you can buy the terminals from cheap and the UK battery's have a lot more kick before i changed mine if i was doing short runs the battery would die or if i listened to radio while parked i could not restart with out a jump now i have changed to UK spec i have zero issues regards 1 Quote
kingrob Posted March 4, 2015 Posted March 4, 2015 Sorry forgot to say zmanalex would be your best shot to get the bit you posted about he is also the guy i got my battery upgrade from 1 Quote
Piranha Posted March 4, 2015 Author Posted March 4, 2015 Hi mate i think i saw a post where you said you had a JDM car and battery i would advice to do that same as me replace the battery for a UK spec one there are traders on here you can buy the terminals from cheap and the UK battery's have a lot more kick before i changed mine if i was doing short runs the battery would die or if i listened to radio while parked i could not restart with out a jump now i have changed to UK spec i have zero issues regards Thanks for that Tricky-Ricky has also suggested this, so if its worked for both of you its got to be the logical move. Quote
Piranha Posted March 4, 2015 Author Posted March 4, 2015 Sorry forgot to say zmanalex would be your best shot to get the bit you posted about he is also the guy i got my battery upgrade from Would be good to have one trader supply all necessary parts, would the larger d1 spec battery bracket work with the larger UK battery? Quote
kingrob Posted March 4, 2015 Posted March 4, 2015 Ok the bracket you can modify your one it took me 3 minutes to get mine to fit all you really need is the terminals you might need to cut a Bump out of the bottom of your battery tray i had to and then find the biggest battery to fit in there 1 Quote
Piranha Posted March 4, 2015 Author Posted March 4, 2015 (edited) Ok the bracket you can modify your one it took me 3 minutes to get mine to fit all you really need is the terminals you might need to cut a Bump out of the bottom of your battery tray i had to and then find the biggest battery to fit in there Thats good news, what battery did you get, if you don't mind me asking, at the moment mines a bosch s3 and doesn't appear to totally fill up the battery tray. I'm beginning to think its a battery for a micra LOL Edited March 4, 2015 by Piranha Quote
kingrob Posted March 4, 2015 Posted March 4, 2015 Omg now your asking give me 5 mins i will pop the bonnet lol 1 Quote
kingrob Posted March 4, 2015 Posted March 4, 2015 Bloody cold out there !!! I have http://www.exide.info/ea754.html 1 Quote
Piranha Posted March 4, 2015 Author Posted March 4, 2015 Bloody cold out there !!! I have http://www.exide.info/ea754.html Wow thanks for doing that for me, looks nice and snug in there with plenty of power for the in car extras I've added. Looks like I will be upgrading it as soon as I can get all the bits together Thanks again Quote
kingrob Posted March 4, 2015 Posted March 4, 2015 Just make sure to get the Neg on the Left side you need the JDM layout Neg left Pos right thats why i went for that battery 1 Quote
