johnny cobra Posted December 30, 2014 Posted December 30, 2014 Hi Guys I used the Z yesterday and also used the wipers and washers ...... The washer pressure is non existent .... Is there any non return valves in the system ??? the head lamps are perfect ... Or could it just be the pump ?? also what side of the bumper is the screen washer... JC... Quote
Ridz Posted December 30, 2014 Posted December 30, 2014 There have been several recent threads on this topic, so it could be worthwhile to use search. Presumably your washer system hasn't frozen up? If your headlight washers are working then it's unlikely to be the fuse, so it could be the screen wash pump that has failed or the non return valve is blocked. The non return valve is located just behind the brake servo compartment. Just pull the pipework down, unplug the valve and try the washers. Usually most Zed owners dispense with the valve as it frequently blocks. Just use a 5mm straight connector to replace it. If it's the pump, it's located on the underside of the screen wash bottle, the outer rear one of the 3 if you have the coupe. Replacement pumps are readily available from our trusted traders on here or from Europarts. Hope this helps. 1 Quote
Mopedmark Posted December 30, 2014 Posted December 30, 2014 (edited) Halfrauds sell a little non return valve for about £2.50 it transformed, my washers and took me abut a minute to fix Edited December 30, 2014 by Mopedmark Quote
johnny cobra Posted December 30, 2014 Author Posted December 30, 2014 Thanks Guys Nice quick answers as all ways .... JC .. Quote
