liamgdr Posted November 1, 2014 Posted November 1, 2014 (edited) Im currently working on a complete I.C.E install for my zed, I have bought all my equipment just need to sort a wiring kit out. I have 2 amps, 409 wrms + 648 wrms = 1057wrms total. Taking the length of cable into account I believe a 4 gauge will be sufficient, if i was to add more power in the future I would definitely go a bit thicker but I can't see any reason why I would need it. According to a guide I've found, an estimate on the max amps I may draw is 153a, does this mean I should use an similar rated fuse? Most 4awg wiring kits offer fuses in the region of 60-80a, would there be any complications with swapping the fuse out for a higher one? If so what size fuse should I get? Cheers, Liam. Edited November 1, 2014 by liamgdr Quote
Wasso Posted November 1, 2014 Posted November 1, 2014 I was running 1000rms and the suitable fuse for the 4awg, but now running 1,800rms with the same fuse but still off one amp and having no issues. Possibly because you're running two amps a larger fuse will be needed. Size I can't help with though. Quote
liamgdr Posted November 1, 2014 Author Posted November 1, 2014 Cheers Wasso, I'll try the standard fuse for now, maybe buy a slightly higher one as back up. Out of curiosity, what amp are you using? 1800 wrms is pretty big, massive sub? Liam. Quote
Wasso Posted November 1, 2014 Posted November 1, 2014 It's a Audison 5.1k 5 chanel feeding 6 speakers and a sub. Yeah keep a spare and see how you get on Quote
Mike_89 Posted November 4, 2014 Posted November 4, 2014 Im currently working on a complete I.C.E install for my zed, I have bought all my equipment just need to sort a wiring kit out. I have 2 amps, 409 wrms + 648 wrms = 1057wrms total. Taking the length of cable into account I believe a 4 gauge will be sufficient, if i was to add more power in the future I would definitely go a bit thicker but I can't see any reason why I would need it. According to a guide I've found, an estimate on the max amps I may draw is 153a, does this mean I should use an similar rated fuse? Most 4awg wiring kits offer fuses in the region of 60-80a, would there be any complications with swapping the fuse out for a higher one? If so what size fuse should I get? Cheers, Liam. The fuse shouldn't be sized higher than the rated current of the cable as this may cause an electrical fire, as you will end up heating the cable up before the fuse goes (if it goes). If you let me know what amps you are going to be running I will have a look into what fuse size you will require 1 Quote
