Z-Boy Posted April 13, 2014 Posted April 13, 2014 Hi All I have a 06 facefit with bose system, and I,m trying to replace with a App radio 3 from Pioneer , I bought the ICT install kit and it all seems to be the coreect one, But I,m not sure about the wiring with the 29-674 adapter, the ISO connection, which is the black connector on the adapter, that does not fit my Head unit? Do I have to splice the ISO connector that was supplied with the unit to ICT apdater? Any help would be very greatful. Quote
Briggsybriggs1 Posted April 13, 2014 Posted April 13, 2014 Pitchers always help :-) post some up . When I fit my head unit I did not use the ISO connection lead supplied with my head unit. I used the adapter one I got for the 350z Sent from my iPhone using Tapatalk Quote
Z-Boy Posted April 13, 2014 Author Posted April 13, 2014 (edited) The back of my new HU Pioneer SPH DA210 Edited April 13, 2014 by Z-Boy Quote
Z-Boy Posted April 13, 2014 Author Posted April 13, 2014 (edited) ITC wiring adpater 1. Red cricled All OK 2. Blackcircled Only fitts the Cars old ISO connector. 3. Yellow circled is supposed to be the ISO connector, but does not fit the back of the Head unit. 4. Green came with HU. Edited April 13, 2014 by Z-Boy Quote
richard.hezlett Posted April 13, 2014 Posted April 13, 2014 Am I right in saying that you have steering wheel controls as standard with your original Bose system. The lead/leads that u got from Incartec go between the lead that came with your new head unit (green circle?) and the plugs you pulled out when disconnecting the Bose unit. There is a patch lead mentioned on the Incartec website that you might also need. Are the 4 sockets at the bottom right hand corner preouts? Quote
Z-Boy Posted April 13, 2014 Author Posted April 13, 2014 Hi Yes I have the Steering Wheel Controls, well I thought the loom that I got Incartec would mean I did not need to use the one circled in green (the one that came with the head unit) I did get all the cables that incartec said I needed and yes the 4 sockets are the preouts I believe. My main issue seems to be the adapter connection for the ISO don't match, I think some thing is missing!!!! Quote
richard.hezlett Posted April 13, 2014 Posted April 13, 2014 As far as I can see the 4 RCA plugs ( red,white,black and yellow ) will go into the preout sockets. The small black phono plug goes into a socket ( think it's labeled RC ) on the back of the head unit. The 2 bigger white plugs go into the sockets you pulled out of the Bose unit. This leaves the black socket with the yellow circle round it which should plug into the other end of the lead which goes into the back of the head unit. From your pictures I can't see any plugs on the other end of this lead?? One other thing I had to do was put in wires and links to the socket connected to the phono plug depending on the make of head unit. The instructions for this came with the leads. Quote
Z-Boy Posted April 16, 2014 Author Posted April 16, 2014 All sorted out, BIG THANKS BUSTER and THE ZED SHED TEAM. Perfect job. 1 Quote
