ersen.o Posted February 3, 2014 Posted February 3, 2014 I get a very intermittent hesitation when im in a high gear around low revs (2k) and i apply wide open throttle, my mechanic said it might be the MAF so we hooked up a computer on it and i recorded the data, just wanted to know does this data voltage look bad to you, does it show signs of a dodgy MAF sensor as i have no error codes, the 2 maf sensors can read up to and over 1v differences at times? didnt want to go changing parts over for no reason so posting here! help Quote
ersen.o Posted February 3, 2014 Author Posted February 3, 2014 oh, 2nd box is RPM 3rd is Airflow bank 1, 4th is airflow bank 2 Quote
Tricky-Ricky Posted February 4, 2014 Posted February 4, 2014 Planting the throttle at 2K RPM in too high a gear is always going to show some anomalous AFM voltages, basically because your suddenly trying to load the engine in a way its normally not expecting or tuned for, not a good practice in my book. Quote
