Hey guys,
I've recently had my Zed dropped 30mm and spaced (20mm front, 25mm rear). It has developed a noise which I can only decribe as a sort of metallic rubbing.
Its most noticable when on full lock while reversing, but also happens sometimes when going into a corner at speed (30mph +).
I've taken the front wheels off and looked for signs of rubbing in the arches but there is nothing obvious.
Has anyone else had this problem or have an idea of what it could be?
Any help appreciated
Thanks
Dan
Dirt guards at back of discs have been bent when changing suspension.
Bend them back out and you problem will be solved.
Bend them out by hand
