Patch Posted May 30, 2013 Author Posted May 30, 2013 I was using one in our Alfa GT with Bose before i upgraded the head unit. thanks for the link, seems pretty straight forward now. Quote
BulletMagnet Posted May 30, 2013 Posted May 30, 2013 (edited) Found this diagram over at our american cousins and it seems that the amp signal wire is (G/Y), which I assume to be Green/Yellow? Failing that, you could always tap into ACC power Edited May 30, 2013 by BulletMagnet Quote
Patch Posted May 31, 2013 Author Posted May 31, 2013 picked up a 4 gauge wiring kit today, collect my rca converter tomorrow and see how I get on. hu easy to take out? Quote
BulletMagnet Posted May 31, 2013 Posted May 31, 2013 You'll need to remove the centre console plastics from top to bottom. Fairly straight forward, just remember to unplug the wire going to the triple gauges Open top cubby, remove the rubber mat at the front, revealing screws, remove screws, lift plate, remove more screws. Then pull and lift the bottom lip of the gear lever surround, be careful, but firm, it's only held in by clips. Once gear lever surround is off, you will be able to see the screws holding the bottom part of the centre console plastic. It also helps if you unscrew the white AC control box, just don't forget to plug the white flatband cable back in on reassembly. Quote
Patch Posted May 31, 2013 Author Posted May 31, 2013 Thanks, i checked out a video on youtube and it looks easy as pie. Quote
