How do I (remove the B piller cover)
Any one know how to remove the B pillar cover?
I have an annoying noise coming from the drivers side when driving at speeds above (+50>) with the window down.
It sounds like its loose. Any advice welcome.
If you're talking about the outside black covers just before the rear quarter windows, they simply pop off.
Its held on by 3 plastic poppers. If you have like a hard plastic wedge to assist it's easier.
Careful. There's one popper at the bottom and two plastic flanges that you're supposed to slide off upwards. You can pull the whole thing off away fom the car but you'll probably break the middle one. £80 from Nissan if you need a new one.
Guess how I know...
Guess how I know...
Cheers for advice.
If you going to remove them in the Winter, heat the popers up first with a hair dryer otherwise you will snap them. :thumbs:
+1
Did a lot of work on my car this weekend and all of the plastics are a bit scary to work with sub 10 degrees. My cable ties just didn't work - would snap in two if you bent them - I had to heat them up and keep them in my pocket!
