leodspider Posted March 7, 2012 Posted March 7, 2012 Hey guys need a bit of help here. I bought the parrot asteroid headunit off Sarah for the zed. However I'm slightly confused. I read the appropriate threads about the need for wiring looms if I want to keep the steering controls. However I can't find the Right adapter for it. The question is , if I don't want the steering control, should the headunit be just a simple out with the Bose in with the new, without the need of adapters, or I'm I missing something? Don't wanna take the headunit out then realise I need new wiring. Quote
spursmaddave Posted March 7, 2012 Posted March 7, 2012 I always say to try incartec for steering adapters but the site seems to have gone You will still need the normal bose loom which will come with a steering wheel control unit it is just the adapter wire that is headunit specific. Maybe try autoleads? Quote
leodspider Posted March 7, 2012 Author Posted March 7, 2012 Cheers dave I'll give it a try, it might be that the headunit is still fairly new Quote
spursmaddave Posted March 7, 2012 Posted March 7, 2012 Cheers dave I'll give it a try, it might be that the headunit is still fairly new Yeah I expect someone will sort a cable out, have you tried googling it to see if someone has fitted one yet Worst case you fit it without and when comes available add it on Quote
