Hi guys thought I would share a problem with you I experienced with my 370z windows and the remedy.
I disconnected the battery and found my windows failed to go back up when door was opened, therefore if you opened and closed the door a dozen times they ended up being completely open (not a great security feature).
The remedy was to turn the ignition on/off within 2-3 sec whist holding the door window control down 4-5 times, both windows required to be done one at a time. Repeat as required is unsuccessful.
The sync now working as perfectly and car now secure.
Even easier rememdy. Wind down the window all the way without autodown (hold button all the way down), then wind them all the way up without autoup (hold button all the way up) and hold for a few seconds at the top.
This needs to be done whenever you disconnect the battery :thumbs:
