How easy is it to replace the bose amp in the rear
I have fitted a new headunit, new sub (with its own amp)
But im just not satisfied the sound levels go high enough for when i really want to crank it up
So Im thinking of doing away with the bose amp in the rear, and doing a straight swap for another one, is this easy to do?
I understand i need 6 channel amp?
I just feel; the Bose seems to be a bit restrictive, I have replaced all the speakers in the car to handle more power, but not really noticing much difference
Has anyone done this?
Cheers
Dan
I'd suggest that you use the pre-outs from your H/U to power a new 2 channel amp. This amp should then be used to power the speakers in the front doors.....forget about the other speakers behind the seats, they will just confuse the sound. I'm not sure what impedence (ohms) the original front speakers are so I'd suggest replacing the front speakers with a replacement 6.5" set. Also consider sound proofing/deadening your doors for the best results.
Hope this helps?
