Mears5 Posted July 31, 2011 Posted July 31, 2011 Hey Everybody, I changed my brake pads yesterday and when I took out the old pads I noticed there was no metal shim between the calliper and pad on one wheel but there was on the other, should there be one? And is it a big deal if this is missing? Cheers Quote
andlid Posted July 31, 2011 Posted July 31, 2011 Should be one there. Squealing can occur get a set of titanium ones while your at it. Supposed to stop heat transfer a bit from the pad to the caliper. Quote
Mears5 Posted July 31, 2011 Author Posted July 31, 2011 Should be one there. Squealing can occur get a set of titanium ones while your at it. Supposed to stop heat transfer a bit from the pad to the caliper. Thanks mate, The new pads had nothing with them, so i will look into it and see, any suggestions on where to look? Quote
andlid Posted July 31, 2011 Posted July 31, 2011 Should be one there. Squealing can occur get a set of titanium ones while your at it. Supposed to stop heat transfer a bit from the pad to the caliper. Thanks mate, The new pads had nothing with them, so i will look into it and see, any suggestions on where to look? Titanium ones from zman. Quote
Mears5 Posted July 31, 2011 Author Posted July 31, 2011 Should be one there. Squealing can occur get a set of titanium ones while your at it. Supposed to stop heat transfer a bit from the pad to the caliper. Thanks mate, The new pads had nothing with them, so i will look into it and see, any suggestions on where to look? Titanium ones from zman. Ah brilliant thanks mate Quote
kano Posted August 1, 2011 Posted August 1, 2011 Are shims needed with ds2500s? Dont fancy spending £80 on a set of titanium shims! Quote
andlid Posted August 1, 2011 Posted August 1, 2011 Are shims needed with ds2500s? Dont fancy spending £80 on a set of titanium shims! get some shims from their website or halfords then? Quote
kano Posted August 1, 2011 Posted August 1, 2011 Are shims needed with ds2500s? Dont fancy spending £80 on a set of titanium shims! get some shims from their website or halfords then? Will use the shims that came with my yellowstuff pads, if I have to. Quote
