Jobo Posted November 26, 2006 Posted November 26, 2006 Hi Folks, Just wondered what the easiest way of replacing the rear indicator bulbs is? If anyone can help me out a bit thatd be great. John Quote
Liam's Z Posted December 1, 2006 Posted December 1, 2006 Hi Folks, Just wondered what the easiest way of replacing the rear indicator bulbs is? If anyone can help me out a bit thatd be great. John Sorry but first question is WHY??? (Answer,,, lift the lid and pop the caps) Quote
Winged Rodent Posted December 1, 2006 Posted December 1, 2006 Apparently (never tried it myself), if you remove the tail/brake light which is held on by 3 screws (see owners manual for instructions), you can then reach in to the back of the indicator unit to gain access to the bulb. Quote
M13KYF Posted December 1, 2006 Posted December 1, 2006 not sure that is the case. Removed the rear brake light cluster myself and there was no visible access to the rear indicator. I thought it was a bumper of job. Quote
DJ Dunk Posted June 3, 2007 Posted June 3, 2007 Just changed my rear indicator bulbs for silver ones and can confirm that by removing the rear cluster you can get access to the indicator/reverse/foglight bulbs Well certainly on a JDM anyway Quote
