DJG.Galliver Posted January 17, 2011 Posted January 17, 2011 Hi Guys, After looking around on the forum, just wanted a but of conformation / piece of mind on a issue I'm having, as a friend of mine has put doubt in my mind saying its transmission?! When accelerating from about 30 mph upwards I am getting a vibration that seems to get louder the quicker I go coming from the front. From what I can find on the forum the suggestions are the wheel bearing hub assembly? I can also feel a slight vibration through the wheel and it seems to slightly be worse when I turn left more than right? So I went with this diagnosis.... I have already purchased and recieved an assembly from Alex (Thanks again ) which will hopefully cure the issue, the car is in the garage tomorrow so only a matter of time till I find out whats up with her! Cheers Dan Quote
Stu350z Posted January 17, 2011 Posted January 17, 2011 Hope it all works out dude! Nothing worse than noises and vibrations and you cant find the source! Lets just hope it is the wheel bearing hub assembly! Got my fingers crossed for you dude! Quote
