Roof Rust
James B
I've got an unfortunate problem with rust on my roof, at the front edge where it meet the windscreen (about 3x3cm). The rust is under the paint (which is still watertight). Chaps at Abbey think it was probably some clubsy mofo who changed the windowscreen in the past and when cutting the seal cut the paint letting water creep in.
Sure ZMANALEX will be along shortly but wondered if anyone has had this, any suggestions for best way to fix? I have a creeping bad feeling that this may require a new roof panel and a spray but though I'd put this out to all you fine gents and ladies collective wisdom to see whats what.
Cheers all! :thumbs:
