M9O OEY Posted November 22, 2010 Posted November 22, 2010 Hi all, The last few times iv driven my z upon starting iv heard a squeak that seems to be coming from the rear the faster I drive the faster it gets kind of pointing me towards the wheels . But within 1 min of driving it's gone,say as soon as iv driven half a mile.Then after stopping for an hr I start the car again and the exact same happens. Iv visually checked the pads without removing the wheels and they seem ok. Going to check the wkend but any advice / guesses will be greatly appreciated. ATB Newbie Quote
Roo Posted November 22, 2010 Posted November 22, 2010 Sounds like a caliper sticking or not releasing properly. May be nothing. Do you have a friendly garage? If so ask them to have a look and give the brakes a clean, its probably just something suchas the caliper piston not releasing properly or rusty. If you breaks are not vibrating and you have plenty of meat on them and your handbrake is holding then they probably just need a clean and lubrication. Quote
M9O OEY Posted November 22, 2010 Author Posted November 22, 2010 Thanks for the reply sound quite a possibility me and a mate are goin to have a look the weekend so just trying to get a few ideas first Quote
Roo Posted November 22, 2010 Posted November 22, 2010 Had this sort of thing on my last car when it jad ben stood for a while. Was just the handbrake not releasing properly. Sounds similar to what you have. May be that all it needs is a clean up. Quote
M9O OEY Posted November 22, 2010 Author Posted November 22, 2010 Hopefully but i drive it every day so think it's more likely to be the piston . Thanks Quote
Darren-B Posted November 23, 2010 Posted November 23, 2010 Inner pads could be low but I`d suggest going to the petrol garage & blasting the brakes with compressed air, this should help clear any debris within the calipers Quote
Darren-B Posted November 23, 2010 Posted November 23, 2010 Alsoif you been exceptionally hard on the brake & got them a wee bit hot this can cause squeaking as the pad surface could be heat damaged. A few moderate heat cycles would normally clear this Quote
M9O OEY Posted December 1, 2010 Author Posted December 1, 2010 Hi , the problem is now even worse every time now upon movement the squuekin noise is embarrassing ,tonight were goin to have a look so any more ideas would be great Thanks M9O OEY Quote
