Woody Posted August 25, 2010 Posted August 25, 2010 Hi All, My ESP, TC and handbrake light all come on on start up when the car and air is cold? This happed for the first time the other morning. I started the car around 5.30am, the air temperature was around 7degrees. All three lights came on (but I didnt notice until I had got half way home, which by then the car was warm). I pulled over turned the car off and back again and all three lights were off. I have driven the car (in warmer air temperatures) since and all has been ok. But I was off to work this morning and the same thing happened, only this time I pulled over when the car was still cold. I turned the engine off and back on again, but the lights would not clear. I continued my way to work with the lights on. When I got to work, the car was warm. I turned the engine on and off again and the lights cleared. Any ideas? Faulty sensor of some sort? Thanks in advance Woody Quote
narcotix Posted August 25, 2010 Posted August 25, 2010 Do you get a CEL light up when this happens? If so then it's worth having the error code read ... Does the car start up as normal when this happens? Quote
Woody Posted August 25, 2010 Author Posted August 25, 2010 Cheers for the reply. Nope, engine light stays off. The car starts up normal and drives as it should. Quote
Woody Posted August 25, 2010 Author Posted August 25, 2010 No. Is there a guide of how to do it somewhere? Ill give it a go and see what happens. Cheers Quote
narcotix Posted August 25, 2010 Posted August 25, 2010 Yes mate .. Here's the link to the ECU Reset Procedure: viewtopic.php?f=35&t=89 The timing of this steps is very important ... I normally use the stopwatch on my phone when I do it ... Quote
Woody Posted September 7, 2010 Author Posted September 7, 2010 I found out that these sequence of lights were down to my very worn breaks . I have changed them today and the lights have stayed off Quote
M13KYF Posted September 9, 2010 Posted September 9, 2010 no indicators to the lights for worn brakes. There is a little plate on the pads that when the pads are very worn will catch oin the disc when braking making a loud squealing sound. Brake fluid level wiil show up a warning light though. May be worth checking your levels. Quote
Woody Posted September 9, 2010 Author Posted September 9, 2010 no indicators to the lights for worn brakes. There is a little plate on the pads that when the pads are very worn will catch oin the disc when braking making a loud squealing sound. Brake fluid level wiil show up a warning light though. May be worth checking your levels. The level is on max. My thinking is, that if the break pads were that low then the level of the fluid would also be very low, as the cylinders would have to extend far out to apply the pad to the disk. Causing the error lights? Now that I have put new pads on, the cylinders would not be extending as far, so the fluid level would go back up? I have been out in the car a fair few times since the new pads were fitted and all the lights have stayed off Quote
