chrisballuk Posted July 26, 2010 Posted July 26, 2010 Installed a new head unit thanks to the helpfull guides it worked first time. However now I have the airbag light flashing. I have done the airbag reset and it stopped but next day has come back. Any idea if there is a wire behind the stereo for the airbags? Please help Quote
Darren-B Posted July 26, 2010 Posted July 26, 2010 Try the airbag reset procedure, mine comes on if the passenger seat is messed around with Quote
M13KYF Posted July 26, 2010 Posted July 26, 2010 check under the seats and make sure all the connectors are properly connected. Here can be an issue. If problem still occurs after a airbag reset procedure then you may have trapped the loom in the seat itself. I had this problem. Had the defective section repaired, cost £40 Quote
chrisballuk Posted July 26, 2010 Author Posted July 26, 2010 Thanks seems like all the shifting around on the seats has dne it and nothing to do with the stereo. Will have a look under the seats when it stops bloody raining. Cheers for your help Quote
M13KYF Posted July 26, 2010 Posted July 26, 2010 if you had moved your seats, defo worth a check. Quote
Aust350z Posted July 27, 2010 Posted July 27, 2010 Don't just do the reset but use the diagnostic stage for the car to tell you where the issue is. Follow the excellent guide here: http://my350z.com/forum/audio-video-and ... ypass.html Quote
