Removed Posted July 8, 2006 Share Posted July 8, 2006 ok guys, who would like to come over @ mine and help out next sarturday 15th July (after the dent removal meet in Warrington) to bleed the brake fluid, change brake lines and change brake pads? I have the tools, parts instructions and manual, just need some help I guess I can offer you some mean pasta dinner cooked properly by yours truly and a glass of wine as a thank you Cheers Link to comment Share on other sites More sharing options...
Liam's Z Posted July 8, 2006 Share Posted July 8, 2006 I'll help you out mate Sooner play with your brakes before I start playing with me own Link to comment Share on other sites More sharing options...
Removed Posted July 8, 2006 Author Share Posted July 8, 2006 I'll help you out mate Sooner play with your brakes before I start playing with me own sorted then! after the dents are repaired? hopefully should be plenty of time to do it! in the manual it says to put the car on 4 axle stands, I reckon we can do it with 2 at a time? (as I don't have 4 ) Link to comment Share on other sites More sharing options...
Liam's Z Posted July 8, 2006 Share Posted July 8, 2006 I'll help you out mate Sooner play with your brakes before I start playing with me own sorted then! after the dents are repaired? hopefully should be plenty of time to do it! in the manual it says to put the car on 4 axle stands, I reckon we can do it with 2 at a time? (as I don't have 4 ) You could lend mine but I don't have any Link to comment Share on other sites More sharing options...
Removed Posted July 8, 2006 Author Share Posted July 8, 2006 I guess we'll do with 2, should't be a problem, we won't need to move the car half way through the bleeding process anyway, just move the axle stands from the back to the front Link to comment Share on other sites More sharing options...
Liam's Z Posted July 8, 2006 Share Posted July 8, 2006 I'll have a chat with the boys and see If I can get a pair Link to comment Share on other sites More sharing options...
Jacko Posted July 8, 2006 Share Posted July 8, 2006 I'd have given you a lift as well but white water rafting that day! So good luck Link to comment Share on other sites More sharing options...
Removed Posted July 8, 2006 Author Share Posted July 8, 2006 manual instructions are relatively straightforward... but with these things, you never know. Ah well, if you don't do it you never learn Link to comment Share on other sites More sharing options...
Liam's Z Posted July 8, 2006 Share Posted July 8, 2006 manual instructions are relatively straightforward... but with these things, you never know. Ah well, if you don't do it you never learn Tell me about it Number of time I've done a 5 minute job that's turned into 5 bloody hours..... 2 heads are better than 1 Link to comment Share on other sites More sharing options...
Guest prescience Posted July 8, 2006 Share Posted July 8, 2006 Are you guys planning to do pics make a guide up later - should be a good one Link to comment Share on other sites More sharing options...
Removed Posted July 8, 2006 Author Share Posted July 8, 2006 only difference from the one we already have will be the brake lines, but i guess we could do our very own one yeah have the following at the ready: 1- next door neighbour-mechanic's SNAP ON massive toolbox (they go on holiday and he wants me to look after his precious tools!) 2- new pads Brembo Sport by Ferodo 3- 3 bottles of Motul RBF600 brake fluid 4- can of brake cleaner 5- NUTS-OFF spray can (ie if nuts don't come off with this, they won't ever move again) 6- draining tubes (don't allow air to be sucked back into the brake lines if brake pedal isn't kept depressed while bleeding) 7- SS brake lines from Technafit (also known as Stoptech Brake lines) 8- 350Z manual printouts 9- copper grease should be it? Link to comment Share on other sites More sharing options...
Guest prescience Posted July 8, 2006 Share Posted July 8, 2006 Cool, first-hand experience is best but guess its gonna be one of those where if it all goes well, you'll have time to do pics but if you encounter probs. probably not gonna have time or the inclination Link to comment Share on other sites More sharing options...
Liam's Z Posted July 8, 2006 Share Posted July 8, 2006 Are you guys planning to do pics make a guide up later - should be a good one Possibly Link to comment Share on other sites More sharing options...
Removed Posted July 8, 2006 Author Share Posted July 8, 2006 ok tools are here, also got a few tips from the friendly neighbour.... let's cross fingers Link to comment Share on other sites More sharing options...
Guest prescience Posted July 8, 2006 Share Posted July 8, 2006 ok tools are here, also got a few tips from the friendly neighbour.... let's cross fingers Let me guess ... Tip #1 - Wait until I get back Tip #2 - There are no more tips Link to comment Share on other sites More sharing options...
lomoto Posted July 8, 2006 Share Posted July 8, 2006 ok tools are here, also got a few tips from the friendly neighbour.... let's cross fingers Let me guess ... Tip #1 - Wait until I get back Tip #2 - There are no more tips LMAO Link to comment Share on other sites More sharing options...
Digsy Posted July 8, 2006 Share Posted July 8, 2006 ok tools are here, also got a few tips from the friendly neighbour.... let's cross fingers Let me guess ... Tip #1 - Wait until I get back Tip #2 - There are no more tips Link to comment Share on other sites More sharing options...
Removed Posted July 8, 2006 Author Share Posted July 8, 2006 nope, more useful tips than that actually we'll be victorious, no worries if PaulW can do it , so can I Link to comment Share on other sites More sharing options...
lomoto Posted July 8, 2006 Share Posted July 8, 2006 nope, more useful tips than that actually we'll be victorious, no worries if PaulW can do it , so can I you got a spare car Val?? Link to comment Share on other sites More sharing options...
Removed Posted July 8, 2006 Author Share Posted July 8, 2006 nope Link to comment Share on other sites More sharing options...
Liam's Z Posted July 8, 2006 Share Posted July 8, 2006 nope, more useful tips than that actually we'll be victorious, no worries if PaulW can do it , so can I So can we What's with the small print anyway? Link to comment Share on other sites More sharing options...
Removed Posted July 8, 2006 Author Share Posted July 8, 2006 was just a joke Link to comment Share on other sites More sharing options...
Spill Posted July 10, 2006 Share Posted July 10, 2006 7- SS brake lines from Technafit (also known as Stoptech Brake lines) You sure you got the right ones didn't think stoptec made them for Brembos?? Link to comment Share on other sites More sharing options...
AndyC Posted July 10, 2006 Share Posted July 10, 2006 Mate I'd be there like a shot (especially with some genuine italian cooking on offer!!) but I'm in Blackpool at a 4 & 1yr old joint birthday (its my Godson so I've gotta go). Sorry Link to comment Share on other sites More sharing options...
Removed Posted July 10, 2006 Author Share Posted July 10, 2006 7- SS brake lines from Technafit (also known as Stoptech Brake lines) You sure you got the right ones didn't think stoptec made them for Brembos?? yeah mate they have those cubic attachments, that I've seen Plus it said Brembo 350Z on the packagins Link to comment Share on other sites More sharing options...
