aka350z Posted May 14, 2009 Posted May 14, 2009 sup i top up the water in the water bottle and the front window jets dont work but the rear one does and the headlight jets work i have tried clearing the holes but no joy please help thanks anthony Quote
tmJak Posted May 14, 2009 Posted May 14, 2009 Have you checked to see if all the pipes leading to the jets are in order? Can you see any leaks anywhere? Quote
aka350z Posted May 14, 2009 Author Posted May 14, 2009 the tubes run from the wipers to the top of the engin bay have not looked from there to the bottle oh where is the bottle and how do i get to it thanks Quote
xStric9x Posted May 14, 2009 Posted May 14, 2009 Ah you have the same problem as me which i hope someone will help me solve over the weekend ( i do have a dribble of water coming through). Quote
M350ZB Posted May 14, 2009 Posted May 14, 2009 If you have access to a airline, blast some air done it, sorted mine in my mg a couple of weeks ago Quote
aka350z Posted May 14, 2009 Author Posted May 14, 2009 do u have to take the front bumper off to get to the water bottle? Quote
marzman Posted May 14, 2009 Posted May 14, 2009 open the engine bay and start unclipping the cowling around the drivers side windscreen... its easy to do. Anyway you'll be able to feel under the cowling eventually and find the pipes leading from your wipers. Unhook this and you have access to it then... you are now looking for a Y pipe connector - this often gets clogged. Unclip the wires from here and stick some wire down it or something to unblock it... Quote
xStric9x Posted May 14, 2009 Posted May 14, 2009 open the engine bay and start unclipping the cowling around the drivers side windscreen... its easy to do. Anyway you'll be able to feel under the cowling eventually and find the pipes leading from your wipers. Unhook this and you have access to it then... you are now looking for a Y pipe connector - this often gets clogged. Unclip the wires from here and stick some wire down it or something to unblock it... I've already done that and i'm kind of thinking the problem is after that point. Quote
tmJak Posted May 14, 2009 Posted May 14, 2009 Ah you have the same problem as me which i hope someone will help me solve over the weekend ( i do have a dribble of water coming through). That's just a natural symptom of ageing Quote
xStric9x Posted May 15, 2009 Posted May 15, 2009 Ah you have the same problem as me which i hope someone will help me solve over the weekend ( i do have a dribble of water coming through). That's just a natural symptom of ageing Cheeky git Quote
aka350z Posted May 15, 2009 Author Posted May 15, 2009 Hey I fixed mine tonight it was the little filter so took it off Quote
M350ZB Posted May 17, 2009 Posted May 17, 2009 Hey I fixed mine tonight it was the little filter so took it off Quote
