v3euk Posted April 18, 2009 Posted April 18, 2009 So, i'm looking to buy a 350Z soon, and i'm just doing research on how to replace the audio system. I'm thinking of the car PC route, using the following Double DIN touch screen (will add a second monitor to the cubby - haven't choosen yet): http://cgi.ebay.co.uk/Double-DIN-Lillip ... 240%3A1318 Assuming i buy a Z with steering controls, i've looked into a way of using these with it: http://www.shipsound.com/product_info.p ... _id=102843 - IR receiver for PC http://www.advancetec.co.uk/acatalog/info%5f728%2ehtml - Steering wheel controls to IR Now does this look like it would fit the Z's steering controls? - As long as i can get the IR signals sent, i'm good to go.. Then finally would be the sound from the PC to the factory amp.. now i have no idea about the connections on car amps, but im assuming this method should work? http://www.zzounds.com/item--HOSYRA154 - PC to RCA connector wired to: http://www.crutchfield.com/p_136CLR2SW/ ... ml?tp=2610 - RCA to amp connectors My main question is does anyone see any major problems with this or are there any other solutions available that i have overlooked? Quote
junglez Posted May 4, 2009 Posted May 4, 2009 Dont see why not, what sort of pc are you going to use? Quote
v3euk Posted May 7, 2009 Author Posted May 7, 2009 Still not decided, i've looked into pre-built car pcs, as i only need a low spec, and i think i've decided it works out cheaper than building it myself, which was the plan in the first place. Quote
Dex Posted May 13, 2009 Posted May 13, 2009 Just to let you know I'm considering the same thing and I'm probably going to use the following as the brains: http://beagleboard.org/ The processor is a few revisions better than the one you have in an iphone and it's absolutely tiny (I'm using one at work and it's about the size of the palm of my hand). There are pre-built linux kernels so it's perfect. I need to decide on the best screen but I don't have too much time at the moment. When I get round to it I'll update people with my progress. Quote
