Trade Shop UK Posted 1 hour ago Posted 1 hour ago Working on your own car can be a rewarding experience, whether you're carrying out routine maintenance, making small adjustments, or simply getting to know the vehicle better. Having the right tools available can make these jobs much easier and can also help avoid unnecessary trips to a garage for simple tasks. A good starting point is a reliable socket and spanner set. Different jobs around a car can require different sizes, so having a comprehensive selection is useful. A ratchet with a range of sockets can make removing and tightening fasteners considerably quicker, particularly when working in areas where access is limited. A torque wrench is another useful addition for anyone who regularly works on their vehicle. Some components need to be tightened to a specific torque rather than simply being tightened as much as possible. Using the correct torque can help prevent damaged threads, loose fasteners, and other avoidable problems. It's also worth keeping a selection of screwdrivers, pliers, hex keys, and trim removal tools in the garage. These relatively simple tools can be useful for everything from interior work to basic electrical jobs and general adjustments. A good inspection light is equally helpful when working underneath the bonnet or in darker areas of the vehicle. For maintenance tasks, having suitable equipment can save both time and effort. A trolley jack and appropriate axle stands, for example, can be useful when a vehicle needs to be safely raised for inspection or maintenance. Safety should always come first, and axle stands should be used on suitable, stable surfaces rather than relying on a jack alone to support a vehicle. Tool quality is another consideration. The most expensive equipment isn't necessarily required for every home mechanic, but poorly made tools can become frustrating to use and may not withstand regular work. Choosing dependable tools for frequently used items while building the collection gradually can be a sensible approach. Keeping everything organised also makes a difference. A toolbox, storage cabinet, or wall-mounted organiser can make it much easier to find the correct tool when needed. After completing a job, returning tools to their proper place also reduces the chance of losing something or leaving equipment around the vehicle. Ultimately, the best garage setup depends on the type of work you enjoy doing. Someone who mainly carries out basic servicing will have different requirements from an enthusiast who regularly works on suspension, brakes, bodywork, or performance modifications. Building a tool collection gradually around the jobs you actually perform is often the most practical approach. Quote
