Keith D Posted December 1, 2025 Posted December 1, 2025 (edited) Yes this old chestnut. I got my hands on a set of Cobra HFCs today and thought it would be interesting to compare them to a set of OE cats and and a set of HFCs I couldn't get through an MOT despite a remap and getting them cooking. Firstly I'm not trying to pick an argument with anyone nor run down any manufacturer - please don't take offence it's not intended. The 200 cel cat brick is ~4" dia and the substrate is ~4" long. Assuming a substrate surface area of 75"sq/inch, the total surface will be 3605"sq. The 300 cel cat brick is ~4" dia and the substrate ~2.3" long. Assuming a substrate surface area of 110"sq/inch, the total surface area will be 3170"sq. About 13% less area. I've never pulled an OE cat apart, and unfortunately mine are back on under the car. If anyone happens to have a set kicking about perhaps you can let me know the dimensions, but if I recall the front down pipe bit has a 400 cl ~4" and ~2" long substrate, and the rear part has another bit of oblong substrate maybe ~4" wide x 2" tall and ~2" long. Assuming a substrate surface area of 150"sq/inch, this makes the total surface area approx 5600"sq. I'm going to see if its feasible to get a local friendly garage to do back to back emissions tests (I'll swap the cats). Seems to me there should be a linear graph of substrate area v performance that can be used to help choose an optimum substrate type and size. I found I can can buy bricks online and I have a local custom exhaust fab who can cut and weld my HFCs with new bricks. I'll keep people posted. Edited December 1, 2025 by Keith D 1 Quote
Keith D Posted December 3, 2025 Author Posted December 3, 2025 Has anyone ever experimented with welding second bricks into the y pipe? That would give a substrate surface are equivalent to stock cats, but all the advantages of higher flow Quote
Keith D Posted December 6, 2025 Author Posted December 6, 2025 (edited) Okay, so some interesting findings from my first test. Standard cats, reset STFTs, warm engine, at fast idle the trims are 105% and AFR 14.6. Then I put on the cobra 200 cel cats, and a radium oil catch kit I bought on black Friday. Reset STFTs again, warm engine, fast idle, the fuel trims are now 95% and AFR 14.6. I was expecting HFCs to reduce backpressure and let a bit more oxygen reach the upstream O₂ sensors at idle. That would bias the sensors lean, and the ECU would add fuel. But I got the exact opposite, the ECU is having to take fuel out.🤔 Edited December 6, 2025 by Keith D Quote
