Ryan Jones Posted April 22, 2024 Posted April 22, 2024 I have noticed that my 06 350z is idling a bit high at around 950-1k when warm if I am stopped waiting at lights ect. I have just left it for a bit but then the other day I switched the car off and back on a again once it was warm while I was waiting at the lights and the idle goes back down to 650-750rpm and stays like that for the rest of the drive which I would consider a more normal idle speed. There is no engine light on at the moment and I have tried the pedal dance before. I think it helped in that past a bit but still doing it now. any advice? I do have a code reader but have lost the charger so I’ll try to find that to see if anything comes up on it but like I say there is no current engine light showing. Quote
mr v6 Posted April 22, 2024 Posted April 22, 2024 Have you tried a thorough clean of the throttle body followed by all the 3 resets? I did that a few years ago & since then mine has been rock steady at 650rpm when fully warmed up. Quote
Ryan Jones Posted April 23, 2024 Author Posted April 23, 2024 I have not yet but It seems I need to start with this. What did you use to clean it with? I’m assuming there must be throttle body cleaners like carb cleaners for example. Quote
mr v6 Posted April 24, 2024 Posted April 24, 2024 I just used plenty of carb cleaner. I opened the throttle body & gave the whole inside a good clean, along with the edge of the butterfly valve, then do the resets, that may take you numerous attempts as they can be tricky. 1 Quote
Ryan Jones Posted May 31, 2024 Author Posted May 31, 2024 Throttle body was cleaned a few weeks ago and did the resets. So far so good after a few weeks so seems to of sorted it with a normal idle of 600-650 now. Quote
