Tom_K Posted September 26, 2018 Posted September 26, 2018 Afternoon all, My 03 350GT has got a fairly annoying gearbox whine so I'm after the better/stronger CD009. I'm based in hampshire so collection is possible from near there but realistically I guess it would need to be couriered. Any help much appreciated. Thanks Tom Quote
evilscorp Posted September 26, 2018 Posted September 26, 2018 Have you tried a fluid change and some molyslip added at the same time? It worked on mine, well I actually liked the racecar gear whine but it went after the fluid change =( many years ago. Quote
Tom_K Posted September 27, 2018 Author Posted September 27, 2018 Thanks for the help but sadly I've tried that. When I bought the car it had a pretty shot DMF and (I assumed) noisy release bearing, so I replaced that with the lightened flywheel, clutch and new bearing. Unfortunately, the noise was still there (goes when you depress the clutch) Then I tried genuine nissan oil with molyslip; the change itself is great, no issue there, but the noise with the clutch out still isn't great. You can hear a sort of backlash when you're in 3rd for example and lift off the throttle. I'll try and get a video for others to reference as that may help. Quote
Tom_K Posted January 27, 2019 Author Posted January 27, 2019 I've had a busy few months but now back on to sorting this car. Bump to see if any of the traders have one? Quote
