Skyrider Posted September 21, 2016 Posted September 21, 2016 Good Evening, Â My 350Z has developed a rattling noise, which is coming from the catalytic converter & associated heat shields, which have suffered corrosion. Â My dealer tells me that the only fix is to replace the entire front end of the exhaust, at considerable cost. Â Can anyone suggest how to fix this at a more reasonable cost, please? Â Thanks. Â Skyrider Quote
evilscorp Posted September 21, 2016 Posted September 21, 2016 remove heat shields and don't use a dealer 1 Quote
Skyrider Posted September 22, 2016 Author Posted September 22, 2016 Thanks for your reply. Â I'm not really familiar with the arrangement of the heat shields, so not sure that I would want to tackle this myself. Â I understand that there are heat shields above & below the converter: I can see that the lower ones are quite corroded & flimsy, but cannot assess the condition of the upper shields. Are these not required to prevent excessive heat getting through the floor into the driver/passenger area? Quote
