Programming the key fob
Sunny1
Hi All, :thumbs:
Does any one know if what i'm being told is correct or not, attached is the word for word comment from an American performance parts centre i stumbled accross recently, they are selling key blades with the fob for around £50 and say its universal to programme for the UK market. :thumbs:
"Yes the setup is the same for all 350Z cars even international models."
Below are the instrution on how to programme the fob
"KEY FOB SETUP
1. Close all doors
2. Insert key into and remove it from ignition key cylinder more then six times within 10 seconds. (Hazard warning lamps will then flash twice.)
Note: Withdraw key completely from ignition key cylinder each time.
If Procedure is performed too fast, system will not enter registration mode.
3. Insert key into ignition key cylinder and turn to ACC position
4. Push any button on key fob once. (Hazard warning lamps will then flash twice.)
5. Do you want to enter any additional key fob id codes? If No - Go to step 9 , if Yes - Go on to next step (6)
Note: A maximum five ID codes can be entered. If more then five ID codes are entered, the oldest ID code will be erased.
6. Unlock the door, then lock again with lock/unlock switch driver side (in power window main switch).
Note: Operate this procedure even if the door is in an unlock state.
7. Push any button on key fob once. (Hazard warning lamp will then flash twice.)
At this time, The oldest ID code is erased and the new ID code is entered.
8. For additional key fobs do steps 6 thru 7.
9. Open driver side door. (END)
After entering ID code, check operation of remote keyless entry system.
Thanks in advance for advise from all.
Nope.
Different procedures for US, EU/UK and JDM.
You've posted the US procedure, GIXXER has posted the UK method (I think?)... and I've not heard of an easy method of manually programming the JDM keys...
Steve
