Is there an ignition live in the engine bay?
I'm wiring in some DRLs but need to tap into an ignition live. I've tried the fuse box by the battery but they all are permanent. Is the only place to feed a wire through from behind the stereo?
Look right at the back of the plenum ........ its at the back and slightly above the plenum .... I think its to do with the fuel ???? it becomes live when ignition is switched on .. hope this helps ...
JC ...
