Installing Rear Parking Sensors
Bosco
Hi,
I am having 4 rear parking sensors fitted on Monday.
Is it possible for them to be installed with the removal of the rear bumper. It look like if you remove the rear tail light and the spare wheel, you maybe be able to pass the wires through the centre grommet.
If you have installed rear parking sensors without the removal of the bumper, can you let me know how you accomplished it.
Thanks
Mask up and mark where to drill holes. Drill holes, you may have to drill through the foam behind aswell.
Place sensors in bumper and run cables to left of car, could be difficult as access from top will be limited and foam gets in the way.
You will still need to remove the left rear light to gain access to the wiring and gromit into the car.
The sensors power comes from the reverse light and you can earth it anywhere.
That's pretty much it. It is possible though.
