jme 350z Posted May 25, 2010 Posted May 25, 2010 around the top of the screen the rubber trim has been loose for a while so stuck it back on and now most of it is hanging off!!! after a good drive to weymouth!!! i peeled the rest of it of to restick it down and cant get it back down properly......think i need a new rubber strip and someone decent to fit it!!!! can anyone help please??? thanks jamie Quote
dominicwellsuk Posted May 26, 2010 Posted May 26, 2010 You should be able to fit a new one yourself with no problem, assuming it has come out as it's dried out or warped, rather than the screen shifting. You'll just need to find some sort of roller tool to run over it and press it into the gap. That's all that is done in the factory. Quote
