Dblock Posted July 9, 2009 Posted July 9, 2009 just out on interset how big is it back there im sure ive seen a photo. that made it look rather large.if it is small say less than half a cube +1 on a decnt 8" and give it amps Its not just the size of sub its the sub spec, e.g. an idmax10" or old school solobaric 10" will need less room then a DD9512 which can use up to 4cuft. Best thing to do is check minium and recomended sealed enclosure size when buying a sub, Also remember when chosing your enclosure its before sub displacement. One trick which im not sure you can use on a sealed but works well on a ported enclosure is wadding. It slows the air down making the sub think its in a bigger box but you lose 3db off the peak. Quote
yokomo Posted July 10, 2009 Posted July 10, 2009 works sealed too . if your already working a set space then defiantly going to be choosing sub around your volume . ona side note has anyone tried these ?? http://www.caraudiodirect.biz/subwoofer ... s-rw6.html being only 6 ers they need just .3 cubes for the pair ported ! Quote
Dblock Posted July 10, 2009 Posted July 10, 2009 works sealed too . if your already working a set space then defiantly going to be choosing sub around your volume . ona side note has anyone tried these ?? http://www.caraudiodirect.biz/subwoofer ... s-rw6.html being only 6 ers they need just .3 cubes for the pair ported ! I haven't heard them but i dont think they will be too good as the new boxster uses something like them and its sounds rubbish. Quote
