violet.yata Posted July 23 Posted July 23 Hey guys, Posted before but imma keep trying as I am non wiser and still very confused. Having an issue with the central locking, the interior switch for the lock does nothing (no sound other then the switch moving, no relay, no lock movement) I can unlock the door with the key and the alarm goes off which can then be turned off by putting the key in the ignition heres the things i have tried - - checked the switches on the drivers side (replaced them aswell) (replaced them again no joy) - Checked the wiring using the US FSM - cant find a UK version so couldn't confirm some steps - Multimeter to check current from wires to grounds blah blah blah all consistent nothing showing any faults in the wiring. - put in a new BCM from ZEMANALEX (still no joy lock button does no thing) For some context i cannot lock the car with the key fobs as neither of them work Quote
heterofrogs1 Posted July 24 Posted July 24 If you have ruled out any issues with the lock mech could be an issue with the fobs. I will assume you've changed the battery? I'd try re-learning the fobs with NDSII. Quote
violet.yata Posted July 24 Author Posted July 24 1 hour ago, heterofrogs1 said: 1 hour ago, heterofrogs1 said: If you have ruled out any issues with the lock mech could be an issue with the fobs. I will assume you've changed the battery? I'd try re-learning the fobs with NDSII. What is NDSII? Quote
