350Z 2003 Roadster: Squeaking noise when pressing the gas pedal + Hard 1st gear and clutch pedal squeaks after use.
Dear all,
I hope this message finds you well.
I've been experiencing a few issues with my 350Z over the past three months and would appreciate your advice to ensure I’m not overlooking anything.
Firstly, I’ve noticed a squeaking noise when pressing the gas pedal. It sounds similar to a belt squeak. I previously had a belt squeal issue, which seemed to disappear as the weather warmed up. I’ve already ordered a new set of belts for replacement, but I wanted to ask if there’s anything else I should check that could be causing this noise.
Additionally, I sometimes struggle to shift into 1st gear. I’ve also noticed that after about 10 minutes of driving, the clutch pedal begins to squeak — especially towards the end of the pedal travel. Interestingly, if I press the clutch quickly or with more force, the noise seems to stop. I’ve read through some forums and ordered a white lithium grease spray to address this.
I also have an appointment scheduled for rust repair on 09/06/2025, and I’d like to address all issues during that visit if possible. I've truly enjoyed driving my Z since I bought it six months ago — it’s a 2003 import with just under 54k miles.
Thank you very much in advance for your help and any suggestions you may have!
