Passenger side window programming
I have just replaced the driver's side window regulator and motor on my 2005 350Z soft top and re-set the window using the button on the motor, before re-fitting the door card, and that side now works perfectly.
The passenger side however does not and goes all the way down as I open the roof and stays down.
Can I re-programme this side using the up/down buttons perhaps or do I have to take off this door card as well to use the motor button please?
If I can do it using the buttons what is the procedure?
Thanks
