SunGodRA Posted February 6, 2008 Posted February 6, 2008 Hi guys - I have had my JDM (02 plate) for about 6 months now, and hadnt noticed a potential issue until the onset of the cold weather. Whilst having a swarm of Kosovans very efficiently detail the exterior of my car, I left the engine running and noticed that although the climate control was set to auto and approx 25degrees, cold air started coming out the floor vents. As soon as I drove off it turned warm then hot. Then after approx 3 miles I got stuck in traffic (standstill) and the air went cold again ! Surely the heater isnt directly linked to the drive chain so that the car has to be in motion to get warm air???? - this must be a fault - Any ideas? Dave Quote
H5 Posted February 6, 2008 Posted February 6, 2008 It is climate control so it will try and keep the cabin a constant temperature and blast air at different temperatures to keep it that way. I would be more worried about letting Kosovans clean your car!! Quote
SunGodRA Posted February 6, 2008 Author Posted February 6, 2008 It is climate control so it will try and keep the cabin a constant temperature and blast air at different temperatures to keep it that way. I would be more worried about letting Kosovans clean your car!! I understand the concept of climate control - but there is a definate change when the car is stationary (to cold air) and when it is in motion (hot air) Quote
H5 Posted February 6, 2008 Posted February 6, 2008 It is climate control so it will try and keep the cabin a constant temperature and blast air at different temperatures to keep it that way. I would be more worried about letting Kosovans clean your car!! I understand the concept of climate control - but there is a definate change when the car is stationary (to cold air) and when it is in motion (hot air) Wasn't taking the p, just checking. That does sound bizarre, have you got the window open while driving? Other than that, I am stumped. Quote
bronzee Posted February 6, 2008 Posted February 6, 2008 Did someone perhaps accidentally hit the centre of the air-cond button and hold it on for a mo?? If so, this will cause the air-cond to switch automatically between "fresh" and "recirc", so that would make a difference to the cabin temperature slightly. Have a look in your owners manual. Quote
SunGodRA Posted February 7, 2008 Author Posted February 7, 2008 Did someone perhaps accidentally hit the centre of the air-cond button and hold it on for a mo?? If so, this will cause the air-cond to switch automatically between "fresh" and "recirc", so that would make a difference to the cabin temperature slightly. Have a look in your owners manual. Nope - it was on recirc and there was no window open either - this wasnt a 'one off' - it now is the 'norm' rather than an exception Quote
Guest prescience Posted February 7, 2008 Posted February 7, 2008 This sounds like exactly the REVERSE of your problem http://www.my350z.com/forum/showthread.php?t=247962 but may give you some way forward. Another thing raised here, have you had any reason to have the lower passenger or driver trims off recently. there was an issue on this forum with the in-cabin sensors, but again it wasn't exactly your issue http://www.350z-uk.com/forum/viewtopic.php?p=9932 Quote
M13KYF Posted February 7, 2008 Posted February 7, 2008 also what is it like with Auto off. Does it constantly blow warm air. This may point back to the point raised above. Quote
ZeddZ Posted February 7, 2008 Posted February 7, 2008 You probably have an air lock in your cooling system.Get it flushed out and bled and it will be fine. Quote
