TX350Z Posted December 29, 2007 Posted December 29, 2007 Hi All, Have my 350Z being shipped over from the States. I know that the US headlights angle is different to the UK angle; and to pass the MOT they have to be adjusted. I was wondering if the headlights could be adjusted to the UK angle or if they needed to be replaced, or if those wonderful headlight stickers were needed to pass the MOT? Any information would be greatly appreciated... All the Best TX350Z Quote
lomoto Posted December 29, 2007 Posted December 29, 2007 You can use tape to adjust beam cut off for MOT purposes , but it wont pass the SVA test..then it must have UK type cut off headlights fitted Quote
TX350Z Posted December 29, 2007 Author Posted December 29, 2007 You can use tape to adjust beam cut off for MOT purposes , but it wont pass the SVA test..then it must have UK type cut off headlights fitted Thanks Lomoto!!! Happen to know any place I might be able to pick some up? Cheers Quote
lomoto Posted December 29, 2007 Posted December 29, 2007 You can use tape to adjust beam cut off for MOT purposes , but it wont pass the SVA test..then it must have UK type cut off headlights fitted Thanks Lomoto!!! Happen to know any place I might be able to pick some up? Cheers Ebay ?? Quote
