Water under drivers seat
Fuppet
As above, i've got an issue with water underneath/back of the drivers seat. Since the warmer weather i haven't had the heater on and the water issue has been solved. Is it possible the heater generates water that could leak into the cabin?
For reference, it has still rained recently, so it isn't due to the weather being dry.
Can't see how the heater would 'leak' to the rear of the seat area and anyway you would see coolant and rad water level drop.
Maybe a hole of some description allowing water in from underneath or from a real hatch or door seal? Can't think it would be anything else.
