350z with 370z alloys, lowering help
Tuck
So I've been specing up lowering springs as I rarely get on the track with my cars, so after researching the forum the choice is between eibach (30mm) and Tein (17mmF/14mmR) and after looking at other peoples zeds I'm inclined to go with the eibach (a very nice price supplied by Ewan at Clarks) the only problem I have is that after measuring arch gap standard (approx 50mm front & 35mm Front) with the 370z alloys (19') is that the front is going to be very close to the arches with spacers fitted! Does anyone have pictures of thier 350 on 19s with either spring fitted? I've scoured the forum but only found pictures with the standard 18s
Edited by Tuck
Tyres are standard for a 370z 245/35/19 front and 275/35/19 rears
Tyres are standard for a 370z 245/40/19 front and 275/35/19 rears
Sure? That's the sizes costco Michelin gave me for a 370z... but then again it is costco
Positive
Okay cheers, I'll bare that in mind as the dealer has fitted a lovely set of ditchfinders to the front. But the 35 side wall would be shorter so that would fill the gap even more than it already does!
Positive
Pm Keyser or Buster on here I think they will know the answer ;)
Buster is the tyre size guru - but he is away at the moment - try a PM he may still pick them up :)
Cheers I'll fire him a pm
I had a slight rub on full lock but nothing serious and I had to tuck the outer arch a tiny bit in the middle but it was so slight I did it by hand.
Is that with eibach springs yeah? I'm looking to put spacers on too but I'm thinking it may rub quite a bit 😠even with the made up tyre size they have fitted
Oh dear, fitted the tein s springs at the weekend and some 25mm eibach spacers and the rear and might of overdone it with the spacers! Sat waaay to far out of the arches to be drivable!
